Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    I am starting to know my way around!
    Jun 2015
    Southern NH
    26" Front suspension?
    Thinking about a 26" wheel for my 03 Electra glide.
    Has anyone done it without air?
    I currently have progressive monotubes up front lowered 2" can these be made to work on a 26" build?
  2. #2
    Mar 2015
    Pittsburgh, Pa
    There was a thread on here about rides with 26 and no air.....
  3. #3
    Aug 2012
    Lots with no air.
    Yes, but 2" is going to limit travel
    Thanks for being a part of my world..
    http://www.shop.choppedbaggers.com
    Like us on Facebook and share us with the WORLD!!!
  4. #4
    Jun 2015
    Southern NH
    Quote Originally Posted by Marc View Post
    Lots with no air.
    I don't have to be down 2" I can only go 1". I'm mostly wondering how the lowered monotubes would work with a bolt on 26.
  5. #5
    Aug 2012
    Idk? Never used a bolt on, I've always removed those and then cut and welded..
    Totally hate bolton..
  6. #6
    No reason you should have any problems with mono tubes with a bolt on neck. The tubes go in the trees either way. Has nothing to do with the neck unless I'm missing something really obvious.
  7. #7
    Jun 2015
    Southern NH
    Quote Originally Posted by F4iguy View Post
    I was mostly wondering about the caps. The monotubes have a built in cap and it looks like the bolt on necks have extensions that replace the cap.
  8. #8
    Aug 2012
    Right it's the caps. The thread pitch is 1/8-27 npt for the tubes.
  9. #9
    Jul 2014
    MC Bagger bolt on 26" kit doesn't use any extension on the forks. I just installed the kit and I'm not running air, just have Progressive lowering springs on my 14 SGS
  10. #10
    Jun 2015
    Southern NH
    Quote Originally Posted by 14FLHXSBOB View Post
    I did the Progressive monotubes because I have an 03 with the cartridge setup on one side.
