Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    I just found this place!
    Mar 2016
    Bike looks great. I was wondering if the extensions are 2-3", if u eliminated them and used the standard length monotubes, wouldn't it be essentially the same as using the extensions with a lowered monotube? Would that be an option?
  2. #12
    May 2012
    Yorktown VA
    Quote Originally Posted by Sinner77 View Post
    My extensions are 2". If you eliminated them and ran standard length anything, you'd probably only have 1.5-2" max of travel.
  3. #13
    Mar 2016
    Quote Originally Posted by Willy_b View Post
    So then is your opinion that even if I use the extensions, I should use standard length springs? Whether the 2" gets added at the top or the bottom, the travel would be affected the same amount no?
  4. #14
    Mar 2016
    I ended up ordering the race tech complete front end kit w emulators. We'll see how they work.
  5. #15
    Chopped Bagger Asset!
    Jan 2012
    Yes. Dropped it about 1.5". I have almost 3" of travel. Using bump stops of course.
    Bike looks killer my brother!
  6. #16
    I am starting to know my way around!
    Mar 2013
    Church Point, La
    Did you have to install an adjustable fairing bracket?
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  7. #17
    May 2012
    Yorktown VA
    Quote Originally Posted by twistedglide View Post
    No. It is a one position bracket made by California Baggers that is designed for the AS 26 bolt on kit.
