Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
  1. #1
    Feb 2015
    Birmingham, AL
    For Sale
    23 Street Glide to 30 Road Glide
    23" 7/7 raked Street Glide going to 30" Road Glide. It will be a lay frame. Audio system as of now will be 4-8", 2-10", 4-ST25's, 2-ST44's, and will be powered by 3 amps. Parts so far
    Camtech - Evil Intensions 13 down outer fairing.
    1 Off Creations - inner fairing
    Yaffe - Razorback gas tank
    Speed By Design - Mack Daddy 14 up rear end and Twisted 8 Lids
    Bad Dad - Competition Killer Side Covers
    Camtech - BMF Chin Spoiler
    HHI - 30 Short Neck and trees, Torpedo Legs, 6 Piston 18" caliper, wrap front fender, Speed King handlebars, and Handlebar controls
    SMT 30" V-Arm wheel and 18" rotor
    Arlen Ness - Foot Controls
    RSD - Engine covers
    Dirty Air - Aluminum shocks, tank, 380C compressor, VU2 valve.
    AirFx - Front air
    Attached Images Attached Images
  2. #2
    Feb 2015
    Birmingham, AL
    For Sale
    Progress so far
  3. #3
    Feb 2015
    Birmingham, AL
    For Sale
    Had to build a reverse cut template since the bike had a frame rake already. Just used the stock template and built off of it backwards, but this obviously must be done on a stock frame. I would suggest a three point alignment. HHI built it for me and used the tank mounts and top of the backbone. If I were to do it again, I would also use the bottom of the backbone and get three points of alignment.
  4. #4
    Feb 2015
    Birmingham, AL
    For Sale
    I built my own alignment fixture. I chose to build it off the frame so it could be set up easily for another bike, and I didn't have to worry about it moving out of position from the frame. I also made the base fixture the same so it could be used on another bike, and I added adjustable legs to level the bike.
  5. #5
    Feb 2015
    Birmingham, AL
    For Sale
    Tig welded up, and wiring hole in backbone cut. Now starting to do some body work. Following Toxtreme's advice and filling the heavy gaps with All Metal. BTW Toxtreme, I don't find it hard to sand at all with a right angle grinder:) LMAO
  6. #6
    Feb 2015
    Birmingham, AL
    For Sale
  7. #7
    Jun 2015
    Cleveland, TN
    Bill, wow some interesting things here! Looking forward to seeing what evolves here.
    Sent from my LG-D850 using Tapatalk
  8. #8
    May 2012
    MA.
    For Sale
    Nice Use of 8020
  9. #9
    Feb 2015
    Birmingham, AL
    For Sale
    Quote Originally Posted by Big Evil View Post
    Nice Use of 8020
    Thanks BigEvil:) Have collected quite a bit of it during my machine building years.
  10. #10
    Feb 2015
    Birmingham, AL
    For Sale
    Got some more All Metal body work done. Think I have it built up enough with the All Metal to start using some lighter weight body filler.
