Page 2 of 20 FirstFirst 123412 ... LastLast
Results 11 to 20 of 194
  1. #11
    Jun 2015
    Cleveland, TN
    Quote Originally Posted by Ferro View Post
    If you are going to run just 9* trees for a 26 you will have very little travel. 2 1/2" at best. Just giving you heads up.
    Yes..... I am aware of this. If it doesn't suit me then I will do a chop neck in the fall if I can get my buddy to help me.
  2. #12
    As long as your aware of It. Cant wait to see It done.
  3. #13
    Jun 2015
    Cleveland, TN
    I pulled the front wheel and removed the stock rotors. They are not that glamorous and trying to keep this on a limited budget for the time being I did a light sanding with a orbital sander and throwing some black spray paint on to hide the lack of shine and chrome. A pretty left side only rotor can come later on. uploadfromtaptalk1435354597760.jpg
  4. #14
    Jun 2015
    Cleveland, TN
    After a couple of hours of work and a lot of learning how this front end works, I did manage to find the stock trees. I am still not sure where to go from here... Guess I have some more research on how these shocks work and how to disassemble them.
    Attached Images Attached Images
  5. #15
  6. #16
    A Manual will be your best friend. LOL Just take your time.
  7. #17
    Feb 2013
    San Tan Valley, AZ, United States
    For Sale
    Yep a manual is your best friend right now.
    I thought I was wrong once but i was mistaken.
  8. #18
    Jun 2015
    Cleveland, TN
    Well as it turns out, the forks and tree came apart really easy. Everything slipped out no problem at all. I spent the rest of the day running around finding a replacement set of neck bearings and a long 6mm and impact. I couldn't get the lower bearing to slide up the tree and found the correct part number in a trailer bearing set. A trip to Lowes and my buddy to borrow an impact wrench and I have the shocks loosened up. Next task is flushing them and adding the correct sized travel limiters before a fresh rebuild. uploadfromtaptalk1435442770538.jpg
  9. #19
    Jun 2015
    Cleveland, TN
    Tricky Trees going on now. I had to drill and tap a hole in the bottom for my dual brake lines connection. It took a little more finesse to make the hard brake lines fit but it wasn't difficult. The holes for the ignition switch weren't tapped so I had to run a 10-24 tap in those too.
  10. #20
    Jun 2015
    Cleveland, TN
    Next question...... Is this the left or right side of the wheel? I know it doesn't matter but the removable hub is this side which makes me think "right" but the tire is mounted like this is the "left" side. What is considered the "correct" way to have the spokes running? uploadfromtaptalk1435450612322.jpguploadfromtaptalk1435450642328.jpg
